nother cooler question
发表于 2021-8-31 23:31:32 | 显示全部楼层 |阅读模式
Like everyone else, im looking to build a cooler. I've search with some help. I am not familiar with coolers, so bear with me. What returns the coolant back to the pan? I was thinking of making the pan sit at an angle and use gravity. Wasnt sure if this would create enough pressure. I would use a ball valve with a section of clear hose to turn the flow off and  to check for flow. Any input would be appreciated. This is still in the planning stages.
GMT+8, 2025-12-26 14:02 , Processed in 0.095667 second(s), 18 queries .
