Small upgrade....
发表于 2021-8-31 23:31:25 | 显示全部楼层 |阅读模式
Sometimes I can't concentrate in my shop when I'm working on a project.... When this happen I always find something else to work on haha last night I was using my press and decided to make  a turn knob on my lathe so I could turn it with my hand. Nothing specal just thought I would shareSIN CITY METAL WORKSvisit my YouTube channel https://www.youtube.com/user/devvon
Reply:HF hydraulics?  What would you charge to make me one if that is the case?  I don't have a lathe but have been wanting to replace the junk HF knob.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Did that replace the nob? or just fit over the existing one?The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:I have that same problem, start working on one thing then I find something else to work on...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by jdh239Did that replace the nob? or just fit over the existing one?
Reply:You need a knurler for your lathe... .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWYou need a knurler for your lathe...
Reply:Or a shaver (What?)  I'll bet you turn your signifigant other's laithe nightly.  Sometimes twice.  With sandpaper!
Reply:Very nice mod .  I think I'll have to do the same thing for my home built press (uses a jet air over 20ton).  Definitely makes it alot easier to lock and unlock the jack.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Nice! I have a few hydro jacks around here that could use a nob! If you want a knurl send it over here and I'll knurl it and send it back no charge. I'm nice like that.
Reply:Originally Posted by VPTNice! I have a few hydro jacks around here that could use a nob! If you want a knurl send it over here and I'll knurl it and send it back no charge. I'm nice like that.
Reply:Originally Posted by wintermuteVery nice mod .  I think I'll have to do the same thing for my home built press (uses a jet air over 20ton).  Definitely makes it alot easier to lock and unlock the jack.--Wintermute
Reply:Originally Posted by wd40prerunnerthanks i have a knurl i kinda need a lesson on using it!
Reply:Originally Posted by DSW Just inquired about that Tuesday night in my lathe class. Threading and knurling were the 2 things I really wanted out of the class. Basic instructions were to turn the OD down to be sure it's concentric. Install the knurling tool and get it cenetered on the work. Run the table in say 15 thou and engage the travel on the bed...I didn't have much luck in the 15 min I had to F with it. I think the junk stock I brought with me was hardened. I had a b!tch of a time cutting and facing the end, then the knurler left no marks even though I cranked it in enough to bow the piece in the centers. I need to pick up some decent steel for next tuesdays class so I can play again if the rest of the class doesn't catch up soon.
Reply:No problem..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Your knob looks good...I may have to make one of those.  DSW - Threading isn't too bad.  I just figured it out a few weeks ago.  Just make sure all the angles are set right and don't touch the cross feed.  As long as you only use the compound it's easy.  Now I just need to figure out knurling.
Reply:Originally Posted by kazlxYour knob looks good...I may have to make one of those.  DSW - Threading isn't too bad.  I just figured it out a few weeks ago.  Just make sure all the angles are set right and don't touch the cross feed.  As long as you only use the compound it's easy.  Now I just need to figure out knurling.
Reply:I had issues too.  A few major things:  Make sure your cutter is ground (or you can buy them) at 60*.  The compound has to be set at the right angle.  The angle is referenced from the cross slide, so you have to double check how your compound is marked.  The 0 reference could be from the spindle centerline or the cross side centerline.  I set mine at 29.5 (you will see people saying 29-30 depending on where you look) and the threads came out perfect.  I might experiment when I get some more experience.  The last thing is ONLY use the compound to feed.  If you move the cross slide it will ruin the threads.  The other thing that helped me is having a VFD to slow the spindle speed so I didn't have to react as fast.  I could thread the course thread and have a little time to think.  Once I get more practice, I should be able to do it at full speed.
Reply:I have been making my living as a machinist for over 25 years and never have cut a thread using the compound, I only feed in with the cross slide. compound is set a t zero so that you can widen the thread root if need be. It is all in how you were trained and what the application is.LarryMiller XMT 304 CC/CVSyncrowave 180 SDLincoln PowerMig 255XTTermalDynamics 52Lincoln 305GComlpete machine shop to back it up
Reply:After some practice this morning I nurled the knob.. Alot better to twist l. This is tge first thing I nurled that came out right  SIN CITY METAL WORKSvisit my YouTube channel https://www.youtube.com/user/devvon
Reply:Looks great!Larry, I think most home shop guys use the compound because they have smaller less ridged machines that chatter like a high school girl when cutting anything more then .010" of a cut especially on two faces of a tool. When feeding the compound only one side of the tool is cutting putting less stress on the machine normally resulting in nicer threads.
Reply:Very nice. Looks good. I may have to make one of these in class for the 20 ton bottle jack I keep in the truck. At least it would give me something useful to practice on in class on Tuesday. Might even splurge... I think I've still got a length of SS prop shaft I could use. I did pick up a few feet of cold rolled in different sizes  the other day if nothing else..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Here's a version for those that don't have a lathe. Made with a drill press and hand tools. Attached Images
Reply:Originally Posted by LarrysmachineI have been making my living as a machinist for over 25 years and never have cut a thread using the compound, I only feed in with the cross slide. compound is set a t zero so that you can widen the thread root if need be. It is all in how you were trained and what the application is.LarryWD40prerunner: After some practice this morning I nurled the knob.. Alot better to twist l. This is tge first thing I nurled that came out right  Looks Great! How much you reckon that puppy costs?Jeff
Reply:Originally Posted by jbaWD40prerunner: After some practice this morning I nurled the knob.. Alot better to twist l. This is tge first thing I nurled that came out right  Looks Great! How much you reckon that puppy costs?Jeff
Reply:Thanks to wd40prerunner for making this for me.  Works great!  Perfect fit! Attached ImagesThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Here is a handle I made for my jack simple for those that don’t have a lathe.On threading the angle of 29.5 using a 60 degree cutter is so you only cut with the leading edge of the tool.  Less work for the tool.  I have not cut a lot  of threads but once you see it don right you then can do it well.  I do not undo the half nut just forward and reverse with the motor drive.  Any way that’s how I do it.attached are some adapter I cut in brass for tig torchs. Attached Images
Reply:Originally Posted by jdh239Thanks to wd40prerunner for making this for me.  Works great!  Perfect fit!
GMT+8, 2025-12-26 14:26 , Processed in 0.094400 second(s), 18 queries .
