Vertical Up Beads Question
发表于 2021-8-31 23:30:36 | 显示全部楼层 |阅读模式
Is it more difficult to run a bead vertical up than a joint?Still trying to get it all figured out but all of my current attemps just look like melted candle wax ripples...
Reply:Hello Scot, more details. Process, electrode type, amperage/voltage, more information. Once you supply some of these details I'll bet you'll get some constructive answers. Best regards, Allanaevald
Reply:If your asking whether or not it is easier to run a vert up bead on flat plate vs a v groove butt weld, I'd go for the v-groove being easier.
Reply:"all of my current attemps just look like melted candle wax ripples... " you could be running your amps too high, but also doing a wieve pattern you can pause briefely (split second) at the corners of your pattern (edge of the bead) this will help to even the molton pool to a nice bead, instead of isicles.just my $.02Travis
GMT+8, 2025-12-26 14:02 , Processed in 0.093079 second(s), 18 queries .
