choosing wire
发表于 2021-8-31 23:30:25 | 显示全部楼层 |阅读模式
My welding buddy uses .030 wire exclusively.Im looking to weld some 18 guage floor pans and figured .023 wire would use less heat to prevent warping.Any help appreciated.1971 Pontiac Lemans Olds 3501973 Buick Centurion Ragtop 4551974 Chevy El Camino Classic 3501976 Pontiac Trans Am 4551997 Honda Valkyrie 6 cylinders,6 carbs.
Reply:I do it with 035 all the time and yes you would need less power to run smaller wire ESAB makes a wire called easy grind for body work and i think it is 030 or 023that is a low power wire for sheet metalBut you still need to tack up properly and weld a bit in one place the go to the opposite side and weld a bit and just keep doing that short weld and be aware of your heat inputhttp://weldingweb.com/vbb/showthread.php?t=190231everything i have done is 035 wire but on my portable i use 75/25 shield gasBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Here's Easy Grind from a local supplier .https://weldingsupply.com/cgi-bin/ei...DEF:OR:130TF44
Reply:Thanks for the links,but does anyone really care what the weld is going to look like under the carpet?I just want to drive my car and melt a few tires.I'm sure you long time welders have pride in doing a great looking job,but most of what I'm doing is not going to be visible.1971 Pontiac Lemans Olds 3501973 Buick Centurion Ragtop 4551974 Chevy El Camino Classic 3501976 Pontiac Trans Am 4551997 Honda Valkyrie 6 cylinders,6 carbs.
Reply:Originally Posted by xcelerationrulesThanks for the links,but does anyone really care what the weld is going to look like under the carpet?I just want to drive my car and melt a few tires.I'm sure you long time welders have pride in doing a great looking job,but most of what I'm doing is not going to be visible.
Reply:Yeah,  but you'll know... everytim you walk by and look at it.You'll k now it's there and it could have been better.  As least that's how I am.
Reply:Originally Posted by jlamesYeah,  but you'll know... everytim you walk by and look at it.You'll k now it's there and it could have been better.  As least that's how I am.
Reply:This is the wrong place to ask for help and when you get answers, you tell these guys you don't give a crap.  Use pop rivits.
Reply:Actually someone suggested some kind of high tech glue for body panels..ran about $70 per tube.I didn't know there was such a thing as easy grind...I just thought you needed to match the wire specs to the heat your going to use.After the floor pans are in there will be quite a bit of insulation and carpet,I was just trying to prevent any warpage or shrinkage.1971 Pontiac Lemans Olds 3501973 Buick Centurion Ragtop 4551974 Chevy El Camino Classic 3501976 Pontiac Trans Am 4551997 Honda Valkyrie 6 cylinders,6 carbs.
Reply:Always first is to match everything to the base metal your welding...wire...heat input ..and warp considerations when doing sheet metal and thing like thatBase metal always first.... matching the filler metal to it and the input to weld with it next..you can always use smaller or larger filler as the situation dictates..where and how long you weld in certain places is what makes a welder out of you knowing were and how much heat to get the results you want and not mess things up warping it ...good fit up... good tack up ...stitch weld or just burn itIt all depends on what your base metal is and joint configurationBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2025-12-26 14:02 , Processed in 0.068131 second(s), 18 queries .
