Fire wood holder
发表于 2021-8-31 23:30:05 | 显示全部楼层 |阅读模式
Here's Hank painting a new fire wood holder,2 3/8" pipe 1/8" thick, was at the scrap yard looking for some square tube for another project.$20.58 for pipe $6 for pipe caps for feet $14 for primer and paint.The boys like to help me cut and split wood. Attached Images
Reply:rotate Attached Images
Reply:not much better, dang computers
Reply:It's good to see he's wearing a respirator for spraying indoors. I'm just hoping the burner isn't lit at the same time however. I usually crank the heat to 90* + with the big propane heater and a circulating fan, and then shut it down to paint/spray and don't fire it back up for quite a while afterwards..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Next time use both straps on the respirator so it actually protects you... Leaving it loose means you will not maintain a seal and will be exposed to whatever you are trying to protect yourself against.   No sense wearing it if you don't wear it right.-DaveXMT304 with: 22A Feeder, or HF251 Hi Freq DC TIG air cooled
Reply:He wouldn't paint til I provided a MSDS on the paint.
Reply:It would be a lot easier to paint if you put the rack on the floor instead of up on the wall.
Reply:Iphone photo emailed to me downloaded and posted sideways. ???????seems simplerotate and save, 180* what the heck????? why not 90* like it showed up on the computer?
Reply:I was thinking the same thing re: mask strap and propane heater.  Maybe he's got a good insurance policy on his and has rubbed the last nerve raw??? har har har..........Photo posting solution: Take iphone, place on scanner bed, rotate, scan image on screen, save, post. Or go the old school way and print the photo first, THEN scan it in.........200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Originally Posted by aandy767Iphone photo emailed to me downloaded and posted sideways. ???????seems simplerotate and save, 180* what the heck????? why not 90* like it showed up on the computer?
GMT+8, 2025-12-26 14:02 , Processed in 0.102195 second(s), 18 queries .
