Tube bender -- harbor freight tubing roller dies
发表于 2021-8-31 23:28:27 | 显示全部楼层 |阅读模式
Put this together for an upcoming set of projects:[ame]http://www.youtube.com/watch?v=rXHRO-I7SPQ[/ame] Attached ImagesThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:I really like it man.(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Hello jdh239, very nice work, simple and efficient. Also a great way to expand your available tooling and it's uses. Nicely done, Kudos to you. Best regards, Allanaevald
Reply:i agree nice workLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Looks good. Nothing better than building your own tools. Now you need a lathe so you can start making your own dies.
Reply:Slick but when you bent the piece on video you needed to have the pre bent half over your bench not on the floor side. You ran into it doing the bend (you may have addressed it I only watched to the video off point). You may not have left enough room over the bench side for elaborate bends. No doubt there will be refinments keep us posted (more vids).Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by forhireLooks good. Nothing better than building your own tools. Now you need a lathe so you can start making your own dies.
Reply:Originally Posted by dumb as a stumpSlick but when you bent the piece on video you needed to have the pre bent half over your bench not on the floor side. You ran into it doing the bend (you may have addressed it I only watched to the video off point). You may not have left enough room over the bench side for elaborate bends. No doubt there will be refinments keep us posted (more vids).
Reply:ThanksI think I will put that on my to do listDave ReberWadsworth Ohio
Reply:jdh slick tool man! the problem i see you are having with the HF dies is a very easy problem to correct i am a machinist for a living and  that can be fixed in about 30mins. worth of lathe work if you have a buddy that has a lathe have him machine off the end of the roller until the grooves are aligned with each other  when you sit them on a flat surface then machine the other one to the same length and they will be in perfect alignment with each other . maybe you already knew that but it's not a big deal to fix . i like easy simple stuff like that ,why can't our engineers of the world design stuff that  simple ? cool tool man  good luck !chris
Reply:The brackets you used, what size did you make them out of?  I'm thinking the ones the rollers are attached look like 3/16th?  Then the heavy hitch tubing.  I have a couple sets of rollers besides the round die rollers for my HF tube roller.  One is the 1/2", I modified the other for 3/4" square tubing.I wonder if a 1/2" x 4" strap would work for the base?MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Cool!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Originally Posted by MarkBall2The brackets you used, what size did you make them out of?  I'm thinking the ones the rollers are attached look like 3/16th?  Then the heavy hitch tubing.  I have a couple sets of rollers besides the round die rollers for my HF tube roller.  One is the 1/2", I modified the other for 3/4" square tubing.I wonder if a 1/2" x 4" strap would work for the base?
Reply:Originally Posted by jdh239I agree..... any recommendations?  I have been thinking about picking one up.
GMT+8, 2025-12-26 21:28 , Processed in 0.068389 second(s), 18 queries .
