Pipe welding Mig question
发表于 2021-8-31 23:26:16 | 显示全部楼层 |阅读模式
hello everyone,just a quick question, mig welding a double v pipe joint, i can never seem to accomplish a nice root run, unless i do the root run vertical down any tricks or tips for these type of joint i will greatly appreciate
Reply:The only way I have done it to pass xray was with a positioner..
Reply:im not sure to what your problem is but if it is bead roll then make sure you are moving fast acrost the center of your weld then a slight pause at the toe.
GMT+8, 2025-12-27 01:22 , Processed in 0.091438 second(s), 18 queries .
