Possible Money Maker? Fire-Pit Rings
发表于 2021-8-31 23:25:45 | 显示全部楼层 |阅读模式
I saw this on Kijiji today.... looked a hot item to me!It seemed to me that for you folks with a plasma cutter and a welder, this might be a good way to make a few bucks... especially as cottage season is coming. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Yeah, if you have something that will roll 3/16" steel [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Hey, if the steel strip is long enough (16 ft?), you could bend it by hand! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:I'm guessing they have a CNC plasma to cut these out along with the roller..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:We made some firepits up for some friends last year. Pretty useful to have plasmacam for stuff like this. Attached Imageshttp://www.bend-press.com
Reply:Originally Posted by Rick Vespecially as cottage season is coming.
Reply:hotrodmetal shows you don't neccessarily have to have something to roll the steel to make one of these, just flat plate to make as many sides as you want.
Reply:Yeah Bistineau... and hotrodmetal's version doesn't even have a single weld! *** Hex-Head Sheet-Metal Screws! *** Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:I prefer the washing machine tub...... It also let's me bust out the Sawzall and pretend I'm a fireman cutting someone out of a crashed car!!!   Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Centrifuge baskets also work well if you can get hold of one
Reply:DonnvWarner... your 5 pictures are not showing up on my computer... just red x's. SuperArc... your washing machine tub has little customer appeal... no wolves howling at the moon. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:[QUOTE=SuperArc;1015761]I prefer the washing machine tub...... It also let's me bust out the Sawzall and pretend I'm a fireman cutting someone out of a crashed car!!!   Ditto on the tub.====================================Hobart Engine Driven DC stick, Chry slant 6AO Smith A225ULincoln SP 175T Miller Dialarc HF-PJD Squared ModIII Tube Bender
Reply:Originally Posted by Rick VDonnvWarner... your 5 pictures are not showing up on my computer... just red x's. SuperArc... your washing machine tub has little customer appeal... no wolves howling at the moon.
Reply:Originally Posted by SuperArcWhen I'm out in he boondocks, smokn a Dominican...
Reply:Originally Posted by Rick VHey, if the steel strip is long enough (16 ft?), you could bend it by hand!
Reply:Why didnt I think of that?!?I bet you could sell a scrap washtub with a stand for like $100 to the yuppies[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Here's one I made last year.  This ring is 1/8" thick, 12" tall and a 36" diameter.  I got it at my local steel supplier rolled for $20.  I have a Hypertherm 45 but I don't have a CNC plasma cam so the designs aren't as fancy.  I just downloaded some clipart and traced some templates out of an old mud flap using a Dremel tool.I learned that the corners can't be too sharp as I can't get the plasma tip in tight.  I had to free hand some of the outline.  But, I'm pleased with the results.
Reply:Originally Posted by Tony MoHere's one I made last year.  This ring is 1/8" thick, 12" tall and a 36" diameter.  I got it at my local steel supplier rolled for $20.  I have a Hypertherm 45 but I don't have a CNC plasma cam so the designs aren't as fancy.  I just downloaded some clipart and traced some templates out of an old mud flap using a Dremel tool.I learned that the corners can't be too sharp as I can't get the plasma tip in tight.  I had to free hand some of the outline.  But, I'm pleased with the results.
GMT+8, 2025-12-27 01:51 , Processed in 0.113962 second(s), 18 queries .
