Another............ welding cart story!
发表于 2021-8-31 23:25:24 | 显示全部楼层 |阅读模式
Well, why not!   Here's my finished product!  Materials used: -3/16"  2x2" angle iron (frame)-1/4"   1 1/4" square tube (handle)-1/4"  1 1/4" angle iron (brace to hold the shield gas bottle)- two 350lb load rated (each) stationary casters- two 350lb load rated (each) swivel casters-16 ga sheet metal, polished and clear coated for the shelves.  AKA: "Chinese Stainless" )Equipment:-MM211-.030 Lincoln L-45 wire-75/25% gas-Manual settings, no "auto-set" feature.  Sorry the pics turned out so small, but you get the general idea.  This thing is THICK steel and built like a tank.  95%  of the joints were all mitred into place.  Everything was squared and sanded down before welding.   Primer coated, then two coats of "sail blue" thanks to Rustoleum!  First project using my own brand new MM211. Attached Images "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
Reply:Nice cart
Reply:Nice jobTA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-27 05:30 , Processed in 0.089423 second(s), 18 queries .
