welding off a generator
发表于 2021-8-31 23:25:10 | 显示全部楼层 |阅读模式
Hello - Ive been offered a workshop space at no rent but it is without electricity.  I'd like to run my mig off a generator but want to make sure I get one with enough power and a steady enough current.  My mig is a 135te Clarke mig 230v 50hz 1 phase 30-130 amps.  Can anyone here say they have run a similar model off a genny?  If so, could you recommend which specs I should be looking for in the genny?Thanks in advance.
Reply:Here in the USA we use 60hz so most members probably haven't run generator with 50hzWhere are you located?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Long story short, you need to look up the max inrush current for your welder, the at least double it for your generator's surge rating.Everlast PA160-STH... and that's about it!
Reply:Unless you get at least, I say again at least a 10k "Quality" generator you can trust your asking for trouble. Your machine wont stand dirty power i.e. fluxuations.  surges, irregular voltage, generator running out of fuel and the like, it will be destroyed. If your overseas check the power where your at. Almost everything in the US is 50/60Hz.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:How much do you plan to spend on fuel? Our milk processing equipment uses a lot of variable speed drives and doesn't tolerate power fluctuations at all (goes into a safety shut down mode). During power outages, we run a 150kW generator powered by a big, old Detroit Diesel. Provides power with less fluctuation than line power. The generator was inexpensive (<$5000), but is a thirsty machine. I put it on a trailer for mobile power. It will run all of my welding and cutting equipment simultaneously without issue.Lincoln Precision Tig 185Lincoln Power Mig 256Hypertherm PM 45Everlast 140STSmith O/A
Reply:I see - I think with this advice I'll do what I can to get mains power in, rather than a generator.  At that cost it seems far out of my reach.I'm in London, but the welder is 50 hz as you mentioned.Thanks for all your help, its much appreciated.
Reply:Nigel, maybe you could approach the landlord and suggest cost-sharing for running power to the shop.  Power may be cheaper in the long run, considering generator cost plus fuel. It would benefit both and make his/her place more attractive for renting if and when you move on to other quarters.
Reply:I ran my Miller MM175 for 5 years off of a Coleman 5000w generator I got at Home Depot.  Ive now had it going on 10 years and it works as well as the day I bought it.
GMT+8, 2025-12-27 03:53 , Processed in 0.093339 second(s), 18 queries .
