Stamford, CT welder needed for repair project.
发表于 2021-8-31 23:20:31 | 显示全部楼层 |阅读模式
I have 10 small tables that need a grinding & heavy tac-weld repair made.  Please contact me via PM with your email address. Thank you.
Reply:why not do it yourself? If it's as simple as you say you'ld probably save money that way.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:PM sent - i am from Stamford I would be glad to help...Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:Silverado, I don't see the PM. Thor, I'm not local.
Reply:I am from Fairfield.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:I just re sent the pm... I wonder why it didnt go through the first time.. Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
GMT+8, 2025-12-27 13:03 , Processed in 0.081593 second(s), 18 queries .
