Water Tray cocktail to prvent rusty water? CNC plasma table
发表于 2021-8-31 23:08:21 | 显示全部楼层 |阅读模式
Someone a while back posted the cocktail chemicals needed to help prevent their CNC plasma cutter water tray water from looking like a rusty swamp(can't find it now). Please let me know what you got.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:I use sodium nitrite and physan 20.The sodium nitrite is a corrosion inhibitor. I use about 1/2 lb. to treat ~170 gallons of water. Not to be confused with sodium nitrAte.Physan 20 is a bactericide/viriicide/algaecide/fungicide (kill everything juice) usually used in fountains and such. I use about a table-spoon for ~170 gallons.Visit Tensaiteki.com
Reply:Originally Posted by TensaitekiI use sodium nitrite and physan 20.The sodium nitrite is a corrosion inhibitor. I use about 1/2 lb. to treat ~170 gallons of water. Not to be confused with sodium nitrAte.Physan 20 is a bactericide/viriicide/algaecide/fungicide (kill everything juice) usually used in fountains and such. I use about a table-spoon for ~170 gallons.
Reply:northerntool.com sells a 5 gallon bucket of rust preventative solution I wipe my welding table down with it. it is water based and has no oils.
Reply:Ebay is easiest:sodium nitrite - 2 lb. (US $7.75) : http://www.ebay.com/itm/2-lb-Contain...-/350525654369Physan 20 - 16 oz. (US $12.48) : http://www.ebay.com/itm/Physan-20-16...-/130613985014Visit Tensaiteki.com
GMT+8, 2025-12-28 06:09 , Processed in 0.113328 second(s), 18 queries .
