Propane Shootout
发表于 2021-8-31 23:07:55 | 显示全部楼层 |阅读模式
Did some scrapping this weekend, actually gotta do more today.  So I decided to use propane for the first time to cut some metal.   Usually just use it for the large rosebuds.Cut up some stuff with both gasesThe propane handled the 1/2" plate with ease, and less slag.  I don't like the slow preheat, but it's not a deal killer.  Lighting the stupid torch is different   Little more finicky to get it adjusted, but after a few tries it's pretty routine.  I was running a Victor "0" tip with 350 series regulators, and a model 370 handle (if I remember the number).  It seems to work out ok, and it's cheaper than acetyleneI do like the Victor tip, you can stand off further from the metal than with a Harris tip.  Saves a lot cleaning time on the tip."Any day above ground is a good day"http://www.farmersamm.com/
Reply:You want to keep the tip a LOT higher with LP than with acetylene. The hottest part of a propane flame is way out from the tips of the preheat cones, unlike with acetylene.metalmagpie
Reply:Sambo, Do us a favor and never show the companion photos or video of the methane shootout from Uranus Inc. Poor Kelley...hell, poor mutt!EDIT: Can I borrow the enclosed trailer???? Got Killer interested in Missouri again...glutton for privacy, square footage and acreage. Me...just want a bigger shop...not like yours though. Attached ImagesLast edited by WyoRoy; 07-22-2012 at 12:43 PM.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:C'mon Samm, show us the real beauty of it by burning through that whole "sandwich" at once.
Reply:heck those old trailer axles had the good makens of a CL trailer. Half a dozen wet welding rods and some old ructy scrap and someone would buy it That being said I too switch between acet and propane at times. Although now with the Hypertherm pm 65 the torch is used less and lessMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:LOADED, AND READY TO ROLLAny money received from the metal will probably be offset by the flat tires I'll get going to the scrapyard   70's model Cheverolet pickup meets its makerAnother bunch of steel bound for China I guess "Any day above ground is a good day"http://www.farmersamm.com/
Reply:We used propane on the farm for probably 30 years, just for kicks I tried a tank of mapp gas. WAY better, propane is cheap but found we used bout twice the oxy to get the cut. now with mapp running much better, and still cheaper than acet. however once we get to the bottom of this tank, then we will see what diff in $$$ is. But it runs much hotter, cuts nicer.  Propane was great when oxy was cheap, not so much anymore.
Reply:Originally Posted by nova4353. . .  I tried a tank of mapp gas. WAY better, propane is cheap but . . .  once we get to the bottom of this tank, then we will see what diff in $$$ is. But it runs much hotter, cuts nicer.  Propane was great when oxy was cheap, not so much anymore.
Reply:I use Propylene, acetylene is dinosaur gas. I don't weld with my torch so I like the low cost and versatility of LP based fuel gasses. Oxy is cheap, so it dosent hurt my feelings that I use more. It is all relative I guess.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:If I can get my methane hot enough I can use my butt as demolition torch!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11If I can get my methane hot enough I can use my butt as demolition torch!
GMT+8, 2025-12-28 06:08 , Processed in 0.181788 second(s), 18 queries .
