I got a new Jet Horizonal Bandsaw at school several months ago. We have been using it quite a bit. I started my tool tree and cut one of my mitered pieces a little long. I decided to give the saw a test to see how thin a slice it could cut off. I thought it would walk one way or the other. This was not a new blade and we have cut a lot of metal with it.It sliced off an even pieceI would never had thought it would do this. I will have to try it again in about a year to see how it wears.Last edited by Crabo; 02-02-2013 at 11:02 PM.
Reply:I cut a piece that was .009 and .012 on my habor freight horizontal band saw. New blade and took a lot of time to setup but it did it. I bet if you tried you can cut a piece half as thick as what you just did.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Made some shim washers last year by drilling round stock on end about an inch deep and slicing. I never mic'd any of my pieces... but after an hour of setup and using a 24 tooth blade...I swear I could almost see through them! POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:A buddy of mine was at the shop last week, and picked up a face cut from a 2x2 tube steel job I've got going on. He was amazed at how thin the piece was. Yay Jet!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Very nice! What size and model Jet saw?How many teeth per inch on the blade?
Reply:That is a nice cut, rivals a true cold saw cut.Tim Beeker.
Reply:Its a 7x12 ish, can't recall. Its still running the stock blade, and the blade has cut a LOT of steel. I am going to try a different blade when this one goes. If it doesn't last as long, then I'll go back to a stocker. I don't know the specs on the blade, other than .035, and 3/4".-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Originally Posted by SMC WeldcraftMade some shim washers last year by drilling round stock on end about an inch deep and slicing. I never mic'd any of my pieces... but after an hour of setup and using a 24 tooth blade...I swear I could almost see through them!
Reply:Cam, my stock blade is a 5/8 tpi blade. I am going to go to a bimetal 6/10 when I change it. The saw is a Model HVBS-710S.
Reply:HVS7MW is the model of my saw. 7x12.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Aren't bandsaws cool! You will love that saw every time you use it!
Reply:it would have been impressive if it would have cut all the way through and kept that thin profile. Hell, this is what my dry cut saw did back in the day |
