查看: 13|回复: 0
Using O/A to bend steel, got a question.
发表于 2021-8-31 23:04:29 | 显示全部楼层 |阅读模式
Ok I had some 2.5 by 1/2 flat stock rolled and when I lay it on it's side (1/2 inch side) it does not sit flat. The outside edges are about 1/4 inch off the table. And the middle is sitting on the table. I need to get it flat. And figure heating it should work. I just don't know where to heat it to do what I want. Anyone have any suggestions? Thanks in advance.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:Are you going to weld the joint? It's very common for rolled strips to be slightly helical. Just put the thing on a welding table and clamp everything down flat and weld it and it usually pulls it pretty much flat everywhere. If not, then tap the high spots with a hammer. I wouldn't use heat to try to fix that little thing.metalmagpie
Reply:Yeah it's getting welded into an "I" beam. The rolled steel will be the flanges and I plasma cut the center. The rolled steel was probably done to a 60 ft radius. (it's not much) it has a 4 inch rise in the middle of a 4ft long piece of steel. if that makes any sence.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:Originally Posted by NoBigDeal FabYeah it's getting welded into an "I" beam. The rolled steel will be the flanges and I plasma cut the center. The rolled steel was probably done to a 60 ft radius. (it's not much) it has a 4 inch rise in the middle of a 4ft long piece of steel. if that makes any sence.
Reply:Cool thanks man. I'll be attempting this tomorrow. We shal see how it works out.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:Welding table and a hammer, or use a pair of big bending forks, one clamped to the table, one in your hands. They will need to be about 4' long to have the desired effect. I just corrected the radius and leveled out some 1/2 x 2 for a big window about a week ago.
GMT+8, 2025-12-28 10:15 , Processed in 0.073986 second(s), 18 queries .
