查看: 13|回复: 0
Weld both sides?
发表于 2021-8-31 23:01:01 | 显示全部楼层 |阅读模式
Do you weld both sides when possible?  So if you are making a rectangle frame out of angle with miter corners, should you tack, weld one side, cool the part, then weld opposite side of same seam?  Or should penetration be so good that it can't be improved and likely made worse?
Reply:Yes.I tack inside of each corner, weld from outside of each corner, flip and weld each corner from inside.I sometimes only weld one side if, say, 1/8" angle welded hot but this is where I see the most deformation.Just my methods and they are far from perfect as I don't do this every day.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Not always. If it's something structural, then yes weld both sides. Sometimes, if a weld will be in the way or if it's unneeded, then it'd be unnecessary to weld both sides because of time and cost.-Hillbilly
Reply:To piggyback, if your finished product will be painted or powder coated, then weld all around. Rust lines are never nice to look atTeach Ag Mech - Mike At Home:Lincoln Electric AC225Miller Challenger 172Gas AxeWork:eclectic bunch of 90's vintage blue boxes
Reply:Originally Posted by teachagmechTo piggyback, if your finished product will be painted or powder coated, then weld all around. Rust lines are never nice to look at
Reply:All depends on what you are doing...That comes with experience..... And if it is on the print.......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:There is a very simple answer. Where ever you see this on the prints. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPThere is a very simple answer. Where ever you see this on the prints.
Reply:They are the first, second, third, and sixth letters of the alphabet.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:If you gittar them it's the first four notes in "Money"// Pink Floyd.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by CEPThey are the first, second, third, and sixth letters of the alphabet.
Reply:Actually he missed the 5th letter "E", its on there too!
Reply:Originally Posted by denlow60Hello CEP,what  means the letters a, b ​​, c, f
Reply:This explains some of the common symbols."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by denlow60yes, I understand, but what for relationship have this with weld symbols.
Reply:Originally Posted by HT2-4956denlow60,Those letters are making reference to "notes" that should be found else where on the drawing.
Reply:Originally Posted by denlow60Hello HT2-4956,Thanks for you explanation, but I do not find this back in AWS 2.4
Reply:Originally Posted by OldendumThis explains some of the common symbols.
Reply:Originally Posted by HT2-4956If you look at the master diagram of a welding symbol in AWS A2.4 (which shows you where all the different elements go) it shows that the "tail area" is where information on "process, specification or other reference"  goes.   Since single letters of the alphabet (or individual numbers) don't represent a "process" or "specification" they must be a "reference" to a note that should be found some where else on the drawing.http://www.me.metu.edu.tr/courses/me...eld_symbol.gif
Reply:Off topic a bit but  Originally Posted by CEPOrder this book, a lot of good information in it. http://www.jflfoundation.com/SearchResults.asp?Cat=24
Reply:Originally Posted by newburyOff topic a bit but Can you recommend any basic ebooks for stick welding?  Especially any "Kindle match books" type, where you get the hardcopy and then an ebook copy for nominal price.
GMT+8, 2025-12-28 18:02 , Processed in 0.100699 second(s), 18 queries .
