Just got this from a trade. I should have check the valve but I didn't.... In any case, can you identify this valve? It's a oxygen welding tank that was last certified at June of 1999. It has the same pitch as CGA 540 but the male fitting diameter is just bit smaller than CGA 540. Is there an adapter available to fit the common CGA 540. If not, will LWS trade me another tank with standard CGA540 fitting?Thanks!!
Reply:The worst thing that could happen is you take it in and pay for hydro testing, then have a new valve put in it. Best case is your lws won't notice and they'll just exchange it.Teach Ag Mech - Mike At Home:Lincoln Electric AC225Miller Challenger 172Gas AxeWork:eclectic bunch of 90's vintage blue boxes
Reply:Anything marked on the valve? I see "Sherwood" who is who made the valve. There is also some thing stamped on the wrench flats below the inlet. Sherwood usually marks their valves with what the CGA number is some where on the valve. Take a look and see what other marking you can find on it..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Might be a Compressed Air valve CGA346 it has a .830"-14 RH thread and the CGA540 has a .908"-14 RH thread.Might have to buy a new valve, unless the LWS will tradeGlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:LOL. Who would have thought, just read the label would give me the answer However, this still doesn't make sense. The marking indicate it's a CGA 540, and yet I have never seen CGA 540 with male thread.
Reply:Oops, I don't what gotten into me. The valve shown is indeed CGA 540. I was thinking about CGA 580 I use for Argon where the cylinder side has a female thread. Thank you all.
Reply:They make an adaptor for acetylene, I'm sure they make oxygen ones too. The one in the pic is RH thread onto tank and LH thread for regulator. Attached ImagesThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter |
