What Exactly Is Spot Time ???
发表于 2021-8-31 23:00:31 | 显示全部楼层 |阅读模式
What is spot time on a TIG welder???
Reply:Originally Posted by rahtreelimbsWhat is spot time on a TIG welder???
Reply:I use the spot timer when having the new kid help me tack up plating tanks corner to corner.    When dealing with 4' long seams in 10 gauge material and a FNG it works great to autogeniously tack the corners togetherVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:It's the time it takes to make a spot in your under shorts after you blow a wet fart!
Reply:Originally Posted by InkydoggyIt's the time it takes to make a spot in your under shorts after you blow a wet fart!
Reply:current and time setting for more exact short tacks......Last edited by B_C; 11-26-2012 at 04:04 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by zapsterI could be incorrect but I think it has to do with the fact that some machines have a spot welder feature and it's the time the weld takes place once the process starts.....zap!
Reply:I have a spot timer on my machine, and it does exactly what Dualie describes.  Hit the button, get current for the specified amount of time, then the contactor opens.I don't have a pedal yet so i am using a simple momentary switch on the torch for on/off control.If it doesn't fit, you aren't hitting it hard enough!Miller AerowaveMiller Radiator 1A4.5" DeWalt (with the paddle switch!)Jackson NexGen Helmet
GMT+8, 2025-12-28 18:02 , Processed in 0.229563 second(s), 18 queries .
