Should be CGA580 but it certainly isnt...
发表于 2021-8-31 23:00:31 | 显示全部楼层 |阅读模式
Ok folks, here's the situation.  Needed a new argon regulator/flowmeter on the cheap (first problem, yes I know, we can all safely skip the chicom discussion ).  Ordered this beaut from you -know-where on ebay without even thinking about the differences in International Standards for fittings (DIN, CGA, et. al.).  So when it arrived it had this wonky fitting on it that I have never seen before and have spent the last hour trying in vein to identify.  So this begs my 2 questions; what fitting is it and can I get an adaptor?    I really try to solve my own problems and avoid posting as much as I can, but this one has me both stumped and discouraged. Attached Images
Reply:looks like it could be a medical fitting
Reply:That is a CGA350. That would mean that the regulator was used on Hydrogen cylinders.
Reply:Rex:  I see, thanks.  I found a converter fitting, but I think I'll just go the route of getting a proper (domestic) regulator rather than mucking about with a fitting that costs as much as the POS regulator.Thanks!
Reply:looks more like a 540, for oxygenyou can buy the nut and nipple for a 580 connection, but chances are that is a pressure regulator, not a flow control device (flowmeter/flowgauge)Experience is something you get right after you need it
Reply:Originally Posted by MartiniRex:  I see, thanks.  I found a converter fitting, but I think I'll just go the route of getting a proper (domestic) regulator rather than mucking about with a fitting that costs as much as the POS regulator.Thanks!
Reply:Fred: It's a flowmeter/regulator, you just can see it in the picture... my bad.Cope: yeah that's what I was afraid of so I'm just gonna get a decent setup domestically.
GMT+8, 2025-12-28 18:03 , Processed in 0.112607 second(s), 18 queries .
