Are Harris cutting heads interchangeable?
发表于 2021-8-31 22:53:00 | 显示全部楼层 |阅读模式
I have always thought they are not for the most part, an eBay seller is telling me otherwise. So for example would the cutting head from my model 85 swap over to my model 50 or 43? I looked at the Harris site and they don't show specifics or half of the accessories they make or have made. I see brazing tips interchange some how but it looks like cutting tips are only shared between the 43 and the 85?Could someone shed some light on this subject for me?
Reply:I couldn't tell you the model number, but some years ago I had a Harris that used Victor tips and would interchange with Victor bodies. (the large ones) Only Harris torch I ever owned that was good for any thing.
Reply:Cutting attachments and mixers are specific to the torch body you have.
Reply:I have 2 Harris sets and they are not interchangeable.
Reply:Originally Posted by 12V71I couldn't tell you the model number, but some years ago I had a Harris that used Victor tips and would interchange with Victor bodies. (the large ones) Only Harris torch I ever owned that was good for any thing.
Reply:Ok thanks guys, I found some exceptions with smaller torches sharing cutting heads but couldn't tell if they fit the med and larger size torches.
Reply:Originally Posted by jereThat is the harris "v" 300s torches, or victor 300s.... came across that while hopelessly researching this subject
GMT+8, 2025-12-29 05:27 , Processed in 0.066893 second(s), 18 queries .
