oxy/acety tank mounts
发表于 2021-8-31 22:52:57 | 显示全部楼层 |阅读模式
I just finished up my flatbed, and got welder mounted. I purchased a mega cab dodge dually and picked up a flatbed that I shortened and then installed. The bed I bought used was a 9.5 footer and I took 2 foot out. To make a long story short I need to mount my tanks and was wanting to see what some of you guys did to mount your tanks. I need to mount an argon tank also. Im not sure if you can lay those down horizontally and still be functional. Any imput would be greatly appreciated.Shake and Bake
Reply:I would do what I did, cut the body and mount them low, so your not busting your balls lifting them on the deck. If you search you can see what I did. I don't know what your line of work is so I can't give you that much. I am not a pipeliner, I do lots of equipment repair, and if you see my truck it is what fire me.......at this point in time.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I will do a search, I am doing mainly equip. repair also and on site fab work. My LWS has a ramp that you can back up on to load/unload cylinders and roll them right off the bed so I was kinda leaning towards mounting them horizontal. Will an argon bottle work in the horizaontal possition without damaging guages or causing any hazards to equip.Shake and Bake
Reply:Argon, oxygen, mixed gas all work fine layed down, I had my MAPP tanks on a 45 for years with no issues. The only thing that needs to be upright is acetylene, and straight CO2.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Second the mounting down low. You've got a bed space problem with that mega cab so I would look into mounting them similar to mine or at least some of them. To see mine go to post 310 on this page.http://weldingweb.com/vbb/showthread.php?t=27979&page=13  Here's the image that really shows it but there's lots more in the above thread along with LOTS of other peoples ideas.Last edited by irish fixit; 06-09-2013 at 12:49 AM.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:are they to be used from the bed, or are they on a cart?maybe make a small hydraulic lift gate so you can let machine do the work up/down from the deck.do you have free space under the deck in front of passenger side rear wheels? if so then maybe put some "notches" in the deck and make a small platform underneath for the tanks to sit on? sky's the limit here.
Reply:Thanks for the imput guys, after thinking about it I  believe I am going to mount tanks down in the bed. I will post some pics after I complete.Shake and Bake
Reply:If it was my truck, I'd mount them low that way it's easier to reach the valves to open and close them.Miller 252Miller Bobcat 225Lincoln MigPak 1801959 Hyster forkliftHarris OA torch
Reply:Don't just cut holes in the bed and mount it down into them. You will regret that ever time you change bottles. I see this way to much (I'm a drop dealer so I see a lot of different type rigs).  I know it's hard to see in my pic with all the leads and hose over the bottles but mine slide in from the side with a chain tightened by a bolt holding them tight.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Originally Posted by irish fixitDon't just cut holes in the bed and mount it down into them. You will regret that ever time you change bottles. I see this way to much (I'm a drop dealer so I see a lot of different type rigs).  I know it's hard to see in my pic with all the leads and hose over the bottles but mine slide in from the side with a chain tightened by a bolt holding them tight.
Reply:This is how I did mine, should have done it over a year ago when I bought the truck.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:How's come the entire bed isn't pretty red
GMT+8, 2025-12-29 07:20 , Processed in 0.100338 second(s), 18 queries .
