Building my welding cart
发表于 2021-8-31 22:52:00 | 显示全部楼层 |阅读模式
So I really don't feel comfortable having my water cooler on top of my SW 175 so I started working on the cart today. From the ground up.. I picked up some wheels surplus from my work had to make some axles and wanted something a little more clean looking. So I cut some stock bored a hole on the lathe and tapped it. The 1/2-13 button head cap screws are perfect for the wheels as it just holds the bearing race. I should be getting the materials to get the most of the cart put together.
Reply:Ok a little side project to the welding cart while I wait for material. I took this stuffAnd turned it into this
GMT+8, 2025-12-29 05:27 , Processed in 0.097654 second(s), 18 queries .
