Thanks
发表于 2021-8-31 22:51:59 | 显示全部楼层 |阅读模式
Thanks to Fabn4Fun for the advice on the paint can strainer bags for paint.  Looks like a bag made out of fine mesh.  You can put it over an empty can, and pour the paint through it.  It flows pretty freely, and removes all small particles.IT WORKS, AND WORKS GREAT!!http://www.amazon.com/Gallon-Elastic...t+strainer+bagI'm able to get them cheaper at the Sherwin Williams store, but I included the link for those who aren't familiar with the things.  A MUST HAVE FOR SPRAYING"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Does it work any better than an old pair of panty hose? That's what I have used in the pastCheers Andrew
Reply:Originally Posted by FODFADoes it work any better than an old pair of panty hose? That's what I have used in the pastCheers Andrew
Reply:Originally Posted by WyoRoyNot sure if Kelly uses 'em, but darned sure she broke Sambo of the habit. That gal will make a man of him yet.
Reply:Originally Posted by FODFADoes it work any better than an old pair of panty hose? ...
Reply:Originally Posted by duaneb55 ROFL I had the absolute pleasure of having dinner with Samm and Kelly a couple years ago and if he was wearing them under his jeans then, you couldn't tell. Definitely a couple "meant to be".
Reply:So, anyhow..for those who haven't used these things.Cut the bag thingie up in small pieces, large enough to rubber band around the neck of the paint cup.  Easily get about 6 pieces out of the larger size bags.This is some old paint.I love this stuff, it's relatively cheap, and lasts like IRON.Some really goopy stuff full of chunks of dried chunks.  Been stored a long time.The dried skin on top of the paint in the can.Sprayed like a charm with no clogsThe rack thingie in the background is made of 1" tubing (14ga) with 1 1/2" collars at the top to allow the long piece to slide, and the legs to camber inwards, and move somewhat side to side, and up and down.  This is very handy for painting the little pieces, and it works well on rough ground because the collars are so loose.  Been years since I made it. Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Hey SAM, you should start using john deere green. think how good your lawn will look !!!!
Reply:Originally Posted by BD1Hey SAM, you should start using john deere green. think how good your lawn will look !!!!
Reply:i always use a old pair of drawers
Reply:I use the cone style from my NAPA store that mioxes auto paint and they work great.                                             MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Hey Sam   we use the top of pine trees here in Alabama to beat the paint on our projects. richey
Reply:originally posted by farmersamm - I love this stuff, it's relatively cheap, and lasts like IRON.Some really goopy stuff full of chunks of dried chunks. Been stored a long time.
Reply:Originally Posted by MinnesotaDaveHey sam, do you have to prime before using that paint?  They sell it locally here and I'd like to try it out.No priming would be greatDave J.
Reply:Originally Posted by weldbeadi always use a old pair of drawers
Reply:Originally Posted by farmersammSorry, but you do have to prime it  I use the primer from Van Sickle.  The red oxide is phenominal.  I painted the loader about 12yrs ago, and the places where chains have knocked the paint off are still covered by the original coat of primer, WITH NO RUST.I think this stuff is one of the most closely kept secrets in the paint industry, it leaves all the other brands in the dust  In Oklahoma it's available at Atwoods, not sure where else it's available out of this area.I mean 30 bucks for a good quality alkyd enamel!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  WOWSERS!!!!!!!!!!!!
GMT+8, 2025-12-29 05:27 , Processed in 0.101517 second(s), 18 queries .
