question tig
发表于 2021-8-31 22:47:51 | 显示全部楼层 |阅读模式
i just got my first tig welder and plasma cutter from East Wood. they are 2 hours away but there's a 3 year warranty so i gave it a try. got both for 956$i got some steel but how do i know which filler rod to use?any advice would helpthanks!
Reply:its just some steel plates about 1/8 thick
Reply:1/16" filler is what we usually use with 1/8" at the tech school with steel and stainless. I've also sen guys do the welds with .045 filler or 3/32" filler. It just takes more skill to use the other two.What size filler to use depends on several things. With newer welders, you need a filler large enough that it doesn't just melt off if they don't have perfect torch control. On the other hand filler which is too large either cools the puddle too much, or takes more amps to melt than the base material. Smaller filler also means you have to add more filler, more frequently to get adequate reinforcement. Larger filler means you have to add less filler less frequently, but you may chill the puddle too much and not get the toes to wet in right..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:1/16 what kind of rods? theres so many, should i use er70s6?
Reply:That would be fine. Or ER70S2.
Reply:how thick should be tungsten be?
Reply:The TIG calculator is a handy resource. http://www.millerwelds.com/resources...calculator.php
Reply:post #3 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Tungsten size should be 3/32". Just about any tungsten flavor except green ( pure) would work for steel..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:can you use pure argon for tig welding?
Reply:You bet.
Reply:You guys are saints.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:If you use 25/75% gas on tig it will burn up the tungsten1960 Redface SA-200 F 1621973 Black face SA-200 F 163 with 5" chop2013 Miller Trailblazer 2752013 GMC 3500 welding car
GMT+8, 2025-12-29 16:33 , Processed in 0.107915 second(s), 18 queries .
