Using brass rivets on a knive-handle
发表于 2021-8-31 22:43:47 | 显示全部楼层 |阅读模式
Hello everybody,Not directly a welding related question but i'm gonna ask it annyway!I've got a very old butchersknive wich is my favorite. Now the handle misses some rivets.Can one of the craftsman who are around here explain to me how to rivet it again?Thanx!
Reply:Google "pin spinning" for knife handles.  Fairly simple process, just takes practice.Miller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:That looks like it uses what they call cutlers rivets.http://www.amazon.com/Knife-Cutlers-.../dp/B0094N0UYAI would probably remove the handle, sand away the corrosion and install thoseUsing slow cure epoxy to seal the moisture out from under the handle.You could also use a Corby Rivet - measure dor different sizeshttp://www.amazon.com/Brass-Corby-St...3496034&sr=8-2
Reply:They are called corby rivets, buy some screw them through then file them down flush.http://www.knifemaking.com/category-s/363.htmMiller Maxstar 200 SDPiperliner #10 Gold
Reply:You can buy them threaded as well from McMaster carr or knife makers supply houses. I believe they are called "sex bolts". The drive in ones are more authentic if you get the right size range. The third option is a one piece solid brass rivet that you peen tight then sand the handle flat. If the brass is supposed to fill that heart inlay, you will probably have to use one of those so you can peen it into the depression.
Reply:Thanx guys for the fast response!
Reply:Thanks for asking that !  I am trying to repair an old handle I broke, actually more like replace. I made a full tang out of the broken, half rat-tail tang. Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by CulinaireZakenHello everybody,Not directly a welding related question but i'm gonna ask it annyway!I've got a very old butchersknive wich is my favorite. Now the handle misses some rivets.Can one of the craftsman who are around here explain to me how to rivet it again?Thanx!
Reply:If this project whets your whistle for more like it, see the    info herehttp://www.bladeforums.com/forums/sh...0#post12805770
Reply:I would love to do more blacksmithing/forging.Don't have the time/money/space to do it!
GMT+8, 2025-12-30 00:32 , Processed in 0.095823 second(s), 18 queries .
