Pipe Welding Codes
发表于 2021-8-31 22:43:43 | 显示全部楼层 |阅读模式
Hello everybody, I was wondering what all certs are out their for welding on pipe. Mostly what certs are needed or wanted by employers when welding on the pipeline. If anybody could list most of them that would be awesome and i will very much appreciate it, Thank you in advance!
Reply:For pipe in general, there's dozens of different certs. Every material, every welding process needs it's own cert. Then there's small bore, heavy wall and downhand certs. It depends on the job what certs. are needed. There's been a lot questions about pipelining recently. I think it's pretty fair to say that you don't just get a cert. and get hired on to weld pipeline.
Reply:previous answers are right, but for you to get a start on things, work on ua-28, and watch you tube     https://www.google.com/url?sa=t&rct=...IBUlzg5siE-L5w
Reply:my certs are only needed to hide the Keystone.  fence building only requires a size 50 coat and #6 hat........Cliftonps welcome to the forum
Reply:Thanks for the reply's guys, and is it as hard as they say it is to get a job on the pipelines welding?
GMT+8, 2025-12-30 00:31 , Processed in 0.142681 second(s), 18 queries .
