Lincoln 210 MP or Millermatic 211MVP
发表于 2021-8-31 22:43:13 | 显示全部楼层 |阅读模式
I am looking at purchasing a new machine. I am stuck between the Lincoln 210MP and the Millermatic 211MVP. The prices are similar and I like the ability to stick weld with the Lincoln but know the Miller may be a higher quality. I don't think I would use it everyday but most likely a few times a week. Any help would be greatly appreciated.
Reply:What are you basing the statement on that you know Miller to be higher quality?Hobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:Get the one that makes you happy. There both good.Drivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:Lincoln......simple.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I prefer a dedicated machine for each process. Do you know what happens if the stick goes dead ??  Does that mean the mig won't work either ? I don't know but would investigate .  I have all MILLERS so I would definitely say the 211.
Reply:Originally Posted by geezerbillWhat are you basing the statement on that you know Miller to be higher quality?
Reply:They are both high-quality machines made by reputable companies. The MM211 is a good welder but the 210MP simply provides a lot more value for the money.You may also want to look at the Tweco 211i which is a comparable machine in the same price range.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Originally Posted by BD1I prefer a dedicated machine for each process. Do you know what happens if the stick goes dead ??  Does that mean the mig won't work either ? I don't know but would investigate .  I have all MILLERS so I would definitely say the 211.
Reply:The Lincoln is a newer machine and an inverter. Inverters are more likely to go bang and leave you without a welder.I don't think the TIG kit add on is great value. $630 for a tig torch and foot pedal. And the unit has no argon solenoid, just a valve on the torch. And scratch start only?So the Miller.But if it were me I'd be tempted to go one of 2 directions.1) spend a little more and get a 230-250 amp machine like the Hobart Ironman 230.2) spend a little less and get the Hobart 210 MVP and put the rest towards saving for a good TIG machine (with solenoid, HF start, maybe AC).Hobart 210 MVPHTP Invertig 221 + coolerEverlast SuperUltra 205
Reply:I had decided to go with the Lincoln. I got a call from the company I placed the order with and the customer service rep said they were a month out. Production could not keep up with demand. So I went with the miller and it should be here tomorrow. I am certainly excited about the new machine. I thank all who had some input for me, I will let you know how it works out.
GMT+8, 2025-12-30 02:27 , Processed in 0.136584 second(s), 18 queries .
