Do they make a quick connect for argon hoses? Would a regular compressed air hose connection work?2 invision 456 mp, 456 pheonix, 3 hypertherm 1250, Hypertherm 45,Dynasty 200dx, Millermatic 210 w/ spoolgun, Bobcat 250, 12vs extreme, slugger dry cut saw, slugger mag drill, O/A rig, Piles of tools
Reply:Cancel that found my answer thanks2 invision 456 mp, 456 pheonix, 3 hypertherm 1250, Hypertherm 45,Dynasty 200dx, Millermatic 210 w/ spoolgun, Bobcat 250, 12vs extreme, slugger dry cut saw, slugger mag drill, O/A rig, Piles of tools
Reply:Don't forget to post what ya found inquiring minds want to know. Will Supports Autism Awareness My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:http://store.cyberweld.com/wequdiing...FUSi4AodeA8AbA
Reply:Air hose quick disconnect works just fine..If they hold 120 PSI then 12 CFH is no biggie.I use them on Argon and Helium with my mixer......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Don't know what brand they are but I have them on all my hoses. They even make them for torch hoses. I'll try to get pics next time I'm home if you like.
Reply:Just for those that don't know- air quick connect are only OK for inert gases and Co2DO NOT use them on yer gases that go BOOM.you want this style http://www.westernenterprises.com/en...k_connects.phpEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Yes, just to clarify, mine are made for the torch and bought from my gas supplier. It was so long ago tho that I don't remember anything about them except that I have them.
Reply:This is what i found, weldingweb.com/vbb/showthread.php?t=56177. I do not like the ones matt and broccoli are referring to because they protrude to far out. I want to put this on my dynasty and i am concerned that i might catch it on something and damage it. I have the same fitting on my oa rig so i know how far they protrude. I would really like to get some of the pcl connections referred to in the other thread, but i need to find ones that fit the thread pattern on the dynasty. I think it is type b or 5/8 npt. Anyone have any knowledge that might help?2 invision 456 mp, 456 pheonix, 3 hypertherm 1250, Hypertherm 45,Dynasty 200dx, Millermatic 210 w/ spoolgun, Bobcat 250, 12vs extreme, slugger dry cut saw, slugger mag drill, O/A rig, Piles of tools
Reply:i was only linking those for O/A use I have these on my passporthttp://www.arc-zone.com/index.php?ma...roducts_id=790I'll try to get a pic later and measure it for youEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1Just for those that don't know- air quick connect are only OK for inert gases and Co2DO NOT use them on yer gases that go BOOM.
Reply:If you are not going to use the correct ones like the western's, then you might as well use the best of the wrong ones..http://www.nittokohki.com/en/cupla/Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Hey X,what coupler is it that Esab uses on their Caddy migs?I tried to match it up at MFCP and couldn't. They thought it might be a proprietary fitting.Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Originally Posted by dubl_tHey X,what coupler is it that Esab uses on their Caddy migs?I tried to match it up at MFCP and couldn't. They thought it might be a proprietary fitting. |
