I need an idler solenoid for 1974 SA200
发表于 2021-8-31 22:40:11 | 显示全部楼层 |阅读模式
I need an idler solenoid. A wire broke off mine very close to the housing. No way to repair it unfortunately. I can PayPal payment if it is under $25 or send a money order from my bank.
Reply:If no one here has one, you can check with Weldmart in Clevland, TX (800-460-6474) but I don't know if they would bother with a used idler solenoid.  Same goes for Bill's Welder Repair in OK City (405-232-4799).  New ones run between $80-$90.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Another option is Larry Burross in Dallas, TX.  He has lots of parts for the SA200.Applied Equipment, Inc.2515 Cartwright St.Dallas, Tx 75212214-630-9353 phone214-630-9354 fax888-630-9353 toll-free214-577-9353 cell786-629-9353 computerEmail: [email protected] Millermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:Didn't think about him.How've you been?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks for the links. I'll email them.Quick troubleshooting question for ya'll.I was able to solder a wire to the stub that is coming out of the idler solenoid.I ohmd the coil and it read 26.5 which is real close to 25 ohms that the manual says it should be.I have continuity between the white wire coming off the pc board to the white wire at the solenoid and continuity between the brown wire going to the automatic/high idle switch and the other side of the solenoid.Is there a quick test to see where the problem lies?Last edited by shanghyd; 07-17-2009 at 07:56 PM.
Reply:Is the unit running?  The oil pressure switch has to be closed (engine running) to feed 12vdc+ to the idler solenoid (brown) and PC board (yellow) in order to work considering the board is OK.  The board has to have a good ground to the chassis thru the mounting bolts as well as that is where the solenoid gets its ground (white).MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:The board has a good ground. None of the spade terminals are getting 12V. I put the meter on each terminal and no dice. Which termal has the 12V coming in to the board? The one from the reed switch?
Reply:I assume you mean 12v+ and no, the reed switch completes a ground to the board circuitry when an arc is struck which in turn opens the ground to the idler solenoid (de-energizes) and allows the engine to increase to weld speed.The only terminal that gets 12v+ is the one the yellow wire from the idler switch connects to which is the one to the far right as viewed from the back of the control panel with the PC board installed.The white wire terminal (far left) is the 'controlled' ground to the idler solenoid.The two terminals in the middle connect to the auxiliary outlet (brown) and combined black exciter/brown main generator shunt wires (single brown).  Which to which doesn't matter but I believe an earlier generation board had the 'white' terminal and the left of the two 'brown' terminals swapped.The red wire from the reed switch is usually soldered to its location between the 'yellow' and right hand 'brown' terminals.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane, you always have the greatest electical info for the SA 200 and others too. I know you don't have one tho. Just wondering if you're an electician?? Surely this ain't just a hobby!Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Originally Posted by gizzardgutzDuane, you always have the greatest electical info for the SA 200 and others too. I know you don't have one tho. Just wondering if you're an electician?? Surely this ain't just a hobby!
Reply:It's not for lack of looking it's just they're usually a little to rich for my blood around here although I've missed a couple really good deals in the past.  There's one out there somewhere with my name on it waiting for a restoration and to be put back to work.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by 7A749I have a couple short hoods for sale....Maybe he needs one!
Reply:Originally Posted by duaneb55Didn't think about him.How've you been?
GMT+8, 2025-12-30 11:51 , Processed in 0.101604 second(s), 18 queries .
