Cant seem to find out out of my regulator is a 1/4 NPT thread female.I need a fitting to hook up the standard T series hoses for propane...i have been trying to find one online and failing miserably.
Reply:Where is the original fitting that was in the reg, if you took it out then put it back in. Any LWS should carry a "Y" that would allow you to run two hoses.
Reply:Originally Posted by Jay OWhere is the original fitting that was in the reg, if you took it out then put it back in. Any LWS should carry a "Y" that would allow you to run two hoses.
Reply:I'd still go to the local welding supply and you should have no problem getting the right parts.
Reply:Regulator outlet bushings can be purchased online at my website.Here is the link. Double check szie before you order.Thanks,Jimhttp://www.regulatortorchrepair.com/...gen-outlet-b28OAdoctorwww.regulatortorchrepair.com |
