Aluminum tanks for blackwater storage?
发表于 2021-8-31 22:34:28 | 显示全部楼层 |阅读模式
A friend has a large boat that they're rebuilding.  He has two eighty gallon aluminum tanks that used to be used for marine diesel fuel tanks. The tanks are in great condition and are about twenty years old. He would like to use the tanks for additional black water (sewage) storage.  He was told that sewage would corrode the aluminum and would not be satisfactory. I haven't seen the tanks and I don't know what type of aluminum was used when they were built.  The second option is to use new heavy duty plastic waste tank containers.What say you?  Thanks.Lincoln Precision TIG 185.Flex-Loc 150 torch.Super-Flex hose.Lincoln MIG 180.Victor Oxy/Act torch set.DeWalt Bandsaw with SWAG stand
Reply:Could you have the inside of the tanks coated with something to resist the corrosion ?
Reply:I guess you're question relates to mine.  Would there be corrosion?  If yes, then he will go with plastic and he will sell the aluminum tanks.  If there's no risk of corrosion, then he will use the aluminum tanks. Thanks.Lincoln Precision TIG 185.Flex-Loc 150 torch.Super-Flex hose.Lincoln MIG 180.Victor Oxy/Act torch set.DeWalt Bandsaw with SWAG stand
Reply:Use plastic or stainless.  Blackwater will eat through most other things, including aluminum.  You could coat it with coal tar epoxy, but it wouldn't be worth it and its fairly brittle.
Reply:Black water is corrosive it will eat the alu tanks we always install plastic blackwAter tanks in the boats same as grey water too we don't even use Alu tanks for fresh water on the boats just not worth the risk.
Reply:Here's an idea he has probably not considered, use them for FUEL tanks. Something seems to tell me they were born to be fuel tanks. That 160 extra gallons of fuel can be handy to have when your boating in an area that fuel docks are not readily available.
Reply:Thanks for the input. It seems that aluminum would be a poor choice...Lincoln Precision TIG 185.Flex-Loc 150 torch.Super-Flex hose.Lincoln MIG 180.Victor Oxy/Act torch set.DeWalt Bandsaw with SWAG stand
GMT+8, 2025-12-31 01:07 , Processed in 0.118433 second(s), 18 queries .
