aws d 1.1 3g gmaw help needed
发表于 2021-8-31 22:33:51 | 显示全部楼层 |阅读模式
ok so i tryed to search the fourms but nothing turned up. My companey is paying for me to take a aws d1.1 3g mig test and i have few questions that i cant seam to find on line. first one is what it the hight alowance on the cap pass. 2nd is what should i watch out for during the test. This is the first time ive ever took a aws test. Ive been welding for 6 years but never did much mig up. Ive been welding for the past 2hrs solid praticing. i think ive got it down but the cap hight is makeing me wonder. ill post a picture in the next post. Any advice or details you can help out with i would be very thankful for. there sending me to hobart institute in troy ohio for the test.trailblazer 302 spoolmatic 25a with wc-24thermal arc 161s tig rigmillermatic 200dialarc 250 hf tig rig with spool gun and boxand wanting more......
Reply:trailblazer 302 spoolmatic 25a with wc-24thermal arc 161s tig rigmillermatic 200dialarc 250 hf tig rig with spool gun and boxand wanting more......
Reply:Your boss should buy a copy of the spec, and a SWPS from the AWS bookstore. From what I recall, D1.3 is sheet metal, and qualifies as a single pass weld. In other words there is no cap. Now you can qualify a double bevel groove weld, but welds are from both sides. I could be wrong but the spec and SWPS should tell all.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:This web site might be of some help to you. http://www.gowelding.org/welding-cer...g-vertical-up/Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I think you misread his post Terry. He's doing D1.1 vertical ( 3G). Chevy, your 1st pict looks like you are favoring the left side. Left toe looks good, but you have some undercut on the right. I see a bit of that again in pict #2. There it might be that I'm seeing something not there due to the camera optics, but #1 is definitely undercut.My copy of D1.1 is a bit old ('98). From what I read, looks like your cap shouldn't exceed 1/8" unless it's called to be flush, then it shouldn't exceed 1/32" below flush. Fig 5.4 section 5.24.4.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thank you that's what I was looking for and yes I was favoring my left side. And yes that's under cut I admit it. I haven't done vert up since school 4years ago now they want me to go and pass this test. So I've been practicing my but off. I have found if I square my self up with the test plates I do better. And all most all my plates fall within the 1/8 and under cap. So I should be good. Originally Posted by DSWI think you misread his post Terry. He's doing D1.1 vertical ( 3G). Chevy, your 1st pict looks like you are favoring the left side. Left toe looks good, but you have some undercut on the right. I see a bit of that again in pict #2. There it might be that I'm seeing something not there due to the camera optics, but #1 is definitely undercut.My copy of D1.1 is a bit old ('98). From what I read, looks like your cap shouldn't exceed 1/8" unless it's called to be flush, then it shouldn't exceed 1/32" below flush. Fig 5.4 section 5.24.4
Reply:Originally Posted by DSWI think you misread his post Terry. He's doing D1.1 vertical ( 3G).
Reply:This was one of my cap passes. Maybe it'll help. Critique the heck out of it fellas.
Reply:This is one of my very first attempts at 3-G up hill with Mig.  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Is that the 1in test? It looks good I'm really happy with how mines been comeing out after I got some advice from a fellow worker. And been practicing at home a lot. Originally Posted by FlashedThis was one of my cap passes. Maybe it'll help. Critique the heck out of it fellas.
Reply:Thanks! No sir, just 1/2" plate. I'm not to happy with my cap pass but that's just me being picky I'm sure. The cap pass was also my hardest to "tie down". I think I took 3 3/8" test plates before jumping to the 1/2" plate. I had to square up and look down the gun from directly behind it to see my right side tying in.
Reply:Besides the undercut, those plates look good.i second the 1/8" reinforcement ... unless the inspector or procedure calls for something different.  I just did this same test about 2 months ago for a new employer.  First test i had taken in 6 years.  Then they tossed a 3/8" 3g on me with 1/16" 71T1 wire .... that one worried me but it was surprisingly easier than the 70s-2 test for me.AWS CWI xxxx21711968 SA200  Originally Posted by WelderMike  I hate being bipolar, It's awesome.
GMT+8, 2025-12-31 08:11 , Processed in 0.108300 second(s), 18 queries .
