Small wood chipper
发表于 2021-8-31 22:32:53 | 显示全部楼层 |阅读模式
Ok hear is a small job I did at work a few years back.  Customer bought a new three point wood chipper from are store and than wanted us to modify it to a trailer type to pull behind his mower. I cut the three point A-frame off and used it as a hitch, make brackets for an axle, made a small stand on the back of it to make it stable when not hooked up, and installed a overriding clutch on the PTO so he would not damage his mower. This was the first time I had used the shops mig welder so some of the welds don't look as good as I would like, also sorry all the pics are after it is done I forgot to take any from the beginning. Attached Images
Reply:some of the welds Attached Images
Reply:some more welds Attached Images
Reply:and the last of the welds what do y'all think?? Attached Images
Reply:For towing around a farm/ranch behind that small tractor and at "tractor speeds," I'd be satisfied with those welds from failing.  Nicely done.   Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
GMT+8, 2025-12-31 07:30 , Processed in 0.101155 second(s), 18 queries .
