Finally finished the backyard/camp wood stove.
发表于 2021-8-31 22:32:52 | 显示全部楼层 |阅读模式
I was putting this off for months. I finally finished.  Three propane tanks cut and welded together.  The top burner plate is removable and a portion of a smaller propane tank was welded at the top to support the burner plate.  Also, a cast iron skillet fits nicely over the top hole in lieu of the optional burner plate. The stove is completely modular and stores in the upright position if needed for space, transportation and the rainy season.  The chimney, legs, internal floor grate, top burner plate (3/16" thick) door (3/16") and internal chimney baffle (to help keep the heat within) are all removable and store inside the stove for transport or garage storage purposes.  The angle iron mitered door frame was the most difficult thing to weld on the round front portion of the tank. The door has bullet style hinges and I used my plasma cutter to make vent holes with an adjustable door vent.  Below the bottom door frame is a 2" pipe with another adjustable air intake vent if needed for start-ups.  All done with the dreaded 6013 and a buzzbox.  I used 6013 because propane tanks are so thin.  I could have used a mig welder, but that's no fun.   The welds are just "okay" as I'm not to good with stick when it comes to filling in wide gaps that I had issues with.  But hey, it's just a wood stove for my deer and bear hunts. Attached ImagesLast edited by SuperArc; 04-12-2014 at 01:13 AM.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Looks good to me! As long as it works as expected, it is a WIN with capital letters.Mikel
Reply:Few more before paint... Attached Images
Reply:Love the design, looks like a great pack stove!Sent from my XT907 using TapatalkLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Excellent! Great design. How much does it weigh? How far into the woods are you planning on toteing it?Hobart 125 EZHobart Handler 140Everlast STH 160Generic 210 Amp Welder/GeneratorHobart Air Force 500i plasma cutterChinese 50 amp plasma cutter! Youtube Channel : Henrymac100
Reply:Why is the burner plate removable?  Is it to make the burner hotter by putting the pan on without the plate?  I'm just curious because I don't know, this is not criticism, looks like a nice stove.
Reply:That's a great stove man!
Reply:Is that a chipping hammer handle? Looks good but I thought those would be outlawed in SoCal?
Reply:Looks really good. You should be plenty warm with it.I built one a couple years ago for my tent.
Reply:supera; very professional looking work. imvho oven handles are the only thing those spring loaded chipping hammers are good for.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docweldersupera; very professional looking work. imvho oven handles are the only thing those spring loaded chipping hammers are good for.
Reply:BTW, whenever I go camping in Cali: I use gasoline, lead acid batteries, plastic bottles and stuf to lite my campfiresjust kidding  I have used gas thou, it works good on top of snow. In Cali Last edited by Insaneride; 04-12-2014 at 10:01 PM.
Reply:Man I really like that stove.  Good job.  I'm interested in the. Weight also.
Reply:Looks really good - I like it Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Just noticed you dont have a door gasket, you might consider adding one.
Reply:Originally Posted by HenrymacExcellent! Great design. How much does it weigh? How far into the woods are you planning on toteing it?
Reply:Originally Posted by InsanerideOven handles are good for spring loaded chipping hammers? I didnt know that :wave:
Reply:That's a pretty kool kooker Nice work!
Reply:Originally Posted by InsanerideBTW, whenever I go camping in Cali: I use gasoline, lead acid batteries, plastic bottles and stuf to lite my campfiresjust kidding  I have used gas thou, it works good on top of snow. In Cali
GMT+8, 2025-12-31 07:30 , Processed in 0.099060 second(s), 18 queries .
