Question about Lincoln PowerMig 350MP
发表于 2021-8-31 22:32:49 | 显示全部楼层 |阅读模式
Does anyone know if there is a way to save settings once you have a process setup that works for one project but you need to move to a new project?For instance running GMAW-P wirespeed set too 900 and trim set to 1.2 burnback set too .08 using weld mode set to 14 is there a way to save these to a number so you can just select the # for the weld mode? I know weld mode 14 will keep the last settings but we have more settings than just that one.Question #2 in Lincolns description of GMAW-Phttp://content.lincolnelectric.com/p...ture/nx270.pdfIt list 9 settings that effect the weld. But it would appear that the only true setting that is adjustable is the trim is this correct or did I miss something?As always thank you.
GMT+8, 2025-12-31 07:30 , Processed in 0.076730 second(s), 18 queries .
