Lincoln Invertec V350 Pro
发表于 2021-8-31 22:32:27 | 显示全部楼层 |阅读模式
What would you be willing to pay for an Invertect V350 Pro at auction?  It doesn't come with any leads and there is no opportunity to try it out.  It looks to be well used, but not destroyed.  Is it worth a bid, or would a smarter man pass it up?
Reply:Boy that's a tough question!I bought one used a few years ago for $1,500.00 but I got to play with it all I wanted to. Later turned around and sold it for $1,600.00.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Unless it is guarantied to work or I can test it, I'd treat it as non working and bid accordingly.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by snoeproeUnless it is guarantied to work or I can test it, I'd treat it as non working and bid accordingly.
Reply:how much are you willing to loose outright if its DOA?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Bid low. The control pcb is around 1000.00 and so is the inverter power pcb.the digital power supply pcb is around 500.00. Be aware repairs can get real pricey real fast. Uses the same control pcb and software as the powermig 300/350mp
Reply:Thanks for the good information.  I think I'll pass.
Reply:If you can pick up up for a good  price and it works, you will have one heck of a multi process welder there. I have plenty of time   Under the hood using an Invertec v350 and they are sweet machines in all modes.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-31 07:30 , Processed in 0.098039 second(s), 18 queries .
