Three Strikes Your OUT ..OR.. Third Time's a Charm...I Am Not Sure..
发表于 2021-8-31 22:32:25 | 显示全部楼层 |阅读模式
Lets see..I made this brand new a few years ago..Then they snapped off the journal at the shoulder so I fixed it..Then they snapped it again at the face so I fixed it...Today it's the shoulder AGAIN so I fixed it..I can do these in my Anyway....Roller..Rubber is separating on the ends from too much down pressure in the middle..Yep those are my welds from last time..Broken end..Looks like it was broken for awhile by the looks of it and it finally came apart..Wow! Isn't that swell....... as a extra added bonus they even left the bearing on the other journal for me but I 'aint taking it off..I am not doing anything to that end...Next!...zap!Last edited by zapster; 04-16-2014 at 04:03 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:OK here we go.....Again.Set it up..Center drill..Drill..1 1/2" diameter..NO pilot hole..Bore the end 2.006..Replacement journal done 2.010..Ready for heat..Next!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Heat shrink then 4 tacks..Pass 1..Pass 2..Set up again face to length..Drill and tap end 5/8-11...One more time.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:After threading we need a true running center so we set the compound to 29 1/2 degrees and use the special made tool for centering..Ahhhh...Nice smooth centerhole..Start to finish..FINISHED!A perfectly undetectable repair...(Where Have I Heard THAT Before)...2.437...+.006....-.000And there ya have it.6 Hours of pure fun.I get all the fun jobs.......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Killed it man GREAT job!  I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Beautiful as usual Zap! "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
Reply:zap; great repair. it must have taken substantial abuse to bust it again.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docwelderzap; great repair. it must have taken substantial abuse to bust it again.
Reply:Is there enough space to weld in tapered bushing hubs in the pulley and then use regular shafting w/ tapered bushings?                                            MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by mla2ofusIs there enough space to weld in tapered bushing hubs in the pulley and then use regular shafting w/ tapered bushings?                                            Mike
Reply:Originally Posted by zapsterNot quite sure what you mean there Mike but this is a laminator glue roller..Sorta like a rolling squeegee and the bearings have that groove in both sides where they fit into a fixture and then they can put LOT'S of down pressure on the roller from each end.When the journals start to "Give" they just add more pressure to whatever end and eventually.........SNAP!I don't think any other bearing arrangement can be used here......zap!
Reply:Nice repair. You do get all the fun jobs.
Reply:Originally Posted by M J DThat's a take up bearing in the picture. For a taper lock bushing you would cut out the end plate, or if its a real heavy wall tube you would machine the I.D. of the tube to fit a hub that matched the Taperlock or QD bushing. You would then have a easy to replace shaft.
Reply:If you have a Dodge bearing catalogue there's pics of what I'm referring to. You'll find it in the section on conveyor pulleys. With a thru shaft you wouldn't have all the stresses from welding in the shaft.                                      MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:So what did you do for the other 5 1/2 hours?  J/k. Great work Zap. If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Nice work.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Are we gonna place bets on where it fails next time?I've worked with those style bearings before.  The machines I worked on used air cylinders to apply the down pressure.  Enough cushion that the journals didn't snap.My name's not Jim....
Reply:These guys use hydraulic pressure so there is no mercy......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:How much of the cap did you turn downThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:Originally Posted by RenagadeHow much of the cap did you turn down
Reply:Wow man amazing work Zap!Sent from my iPhone using Tapatalk
GMT+8, 2025-12-31 07:30 , Processed in 0.123037 second(s), 18 queries .
