drilling into SS round and square tubing
发表于 2021-8-31 22:32:12 | 显示全部楼层 |阅读模式
I have this job of drilling 7/16" holes into round tubes of stainless steel 304 with diameter 1.67" of 0.102" thickness and square tubes 1.57"x1.57" of 0.079" thickness of the same material. the job is in the order of 100s.I am liking the JD notcher http://www.google.com/search?sourcei...ddd4f1c4c47812or a drill press with a nice tube vise.for drill bits I was looking at the following Rotabroach® Cuttershttp://blairequipment.com/Rotabroach...a_cutters.htmlWhat are the recommended tools, drill bits, vise...?Last edited by sandare; 02-27-2011 at 11:41 PM.
Reply:I cant comment on a type of vice or notcher, but I have extensively used rotabroach cutters from 7/16"-1" dia on thin walled SS tube with incredible results.  I think the only way to do better would involve a 5 axis mill.Take care of the bits, and use a good cutting lubricant.Have we all gone mad?
Reply:Originally Posted by sn0border88I cant comment on a type of vice or notcher, but I have extensively used rotabroach cutters from 7/16"-1" dia on thin walled SS tube with incredible results.  I think the only way to do better would involve a 5 axis mill.Take care of the bits, and use a good cutting lubricant.
Reply:those are some nice lil kits thanks for posting the link350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:I ended up buying the tube notcher and the rotabroach bits.@sn0border88 thank you for the confirmation about using the rotabroach bits. What cutting lubricant do you use? and how would use it? How much do you dilute it? Do you have a constant pump on the drill?@4sfed/Jim - makes total sense about the 436 rpm. That is the plan. does it matter the hp of the drill press? would 1/2 hp be enough or better go with 1hp since it's running at low rpm and might need good torque? My plan is to apply good pressure.
Reply:Originally Posted by sandareI ended up buying the tube notcher and the rotabroach bits.@4sfed/Jim - makes total sense about the 436 rpm. That is the plan. does it matter the hp of the drill press? would 1/2 hp be enough or better go with 1hp since it's running at low rpm and might need good torque? My plan is to apply good pressure.
Reply:Originally Posted by 4sfedPS - whale oil is the best cutting oil for stainless . . . if you can find/afford it.
Reply:Originally Posted by Donoharmdoes it smell like whale bbq when you weld the pipe ???
GMT+8, 2025-12-31 07:31 , Processed in 0.070425 second(s), 18 queries .
