Thought I Would Try This!!!
发表于 2021-8-31 22:31:58 | 显示全部楼层 |阅读模式
I have never been a big fan of torch mounted argon valves. I had some stainless steel plate, a stainless hinge and a small pneumatic valve laying around. I cobbled this foot operated valve together in about 1/2 hour. I needed to buy a few small brass fittings to hook it up. The other thing that is nice about this is since I eliminated the valve on the torch and was able to to use a standard #17 torch I was able to move the pendent switch up underneath the backcap instead of having it side mounted. I prefer it up underneath the backcap so I can control it with my index finger. Last edited by rahtreelimbs; 03-16-2014 at 06:37 PM.
Reply:Pretty soon you will be playing the drums!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterPretty soon you will be playing the drums!...zap!
GMT+8, 2025-12-31 07:31 , Processed in 0.100423 second(s), 18 queries .
