Friction welding ... Wood??
发表于 2021-8-31 22:24:12 | 显示全部楼层 |阅读模式
Saw this on YouTube.  Apologies if it's made the rounds. Work has had me under water for a month. Now going to Germany for a month. Sent from my iPhone using TapatalkRegards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Under water literally?
Reply:I don't buy it.  They've managed to bond two pieces of wood together with molten carbon in the middle.  But I wouldn't call that a weld by any means.
Reply:Because that is just so much easier than glue?
Reply:not welded, just stuck together with char and wood resin.
Reply:Are they giving any info on tensile, shear or compression testing? Those numbers will show the truth.
Reply:Originally Posted by FlashedUnder water literally?
Reply:Originally Posted by seandaAre they giving any info on tensile, shear or compression testing? Those numbers will show the truth.
Reply:If you rub two assholes together really hard they'll stick, lets call it ******* welding!
GMT+8, 2026-1-1 05:49 , Processed in 0.115988 second(s), 18 queries .
