SA200 starter solenoid?
发表于 2021-8-31 22:13:47 | 显示全部楼层 |阅读模式
Anyone know of a suitable replacement solenoid for a F163 , code6792. a 1970 year model. Would like to get from NAPA or Advanced, someone local if possible. Thanks"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Take the solenoid to napa and have them match it. Your starter should be a Delco-Remy.
Reply:When you get your new part could you post the number to the sa-200 sticky?Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:I will post when I get the PN, starter should be a DR 10 MT from what I am reading."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2026-1-2 06:49 , Processed in 0.101544 second(s), 18 queries .
