180T problem
发表于 2021-8-31 22:13:46 | 显示全部楼层 |阅读模式
OK, having a weird problem. In setting B it won't work. The wire just heats up and curls up. Kind of like if you squeezed a tube of tooth paste out. A and C work fine. What would be the first thing I should check?Thanks,WillLincoln Promig 180
Reply:Pull the covers and check the wires attached to the back of the selector switch. Chances are a wire fell off of or burnt off the switch.
Reply:The selector switch is part of the control pc board. If it is still under warranty. Get it to a warranty shop for a new pc board. It's a small selector switch that at first look appears to be a pot. IF it is out of warranty. say ouch the pcb is over $300
Reply:Originally Posted by ccawgcThe selector switch is part of the control pc board. If it is still under warranty. Get it to a warranty shop for a new pc board. It's a small selector switch that at first look appears to be a pot. IF it is out of warranty. say ouch the pcb is over $300
Reply:3 years warranty, so it's still valid till 2011
GMT+8, 2026-1-2 06:49 , Processed in 0.098608 second(s), 18 queries .
