Where to get a 240 outlet for front of Weldanpower?
发表于 2021-8-31 22:13:46 | 显示全部楼层 |阅读模式
I got a couple of 115 V outlets at Lowe's, but they didn't have any 240(220, whatever you want to say) outlets like what is on the Weldanpower. They just had some oven and dryer types. Haven't tried Home Depot yet, won't be til next weekend, so just looking for suggestions. Hoping this won't be that hard to find. Btw, I got the front panel blasted at work. Then I got impatient (and worried about it rusting) so I painted it without doing any other prep. Primer and Enamel. Thinking about doing some sanding and re doing it. The only part that turned out really nice was the part that the big metal label goes on on the top half.  Patience is not one of my best virtues. Haven't gotten the bridge rectifier yet, hoping it comes in the next couple of days. Anxious to get this together to see if that fixes the no output issue.  My Pinto car project has hit a major snag, hoping that I can at least get this welder working right. I added a picture showing the old outlet.Thanks,Russ Attached ImagesLast edited by russ69coupe; 09-13-2010 at 05:24 AM.RIP Mallory, we miss you.
Reply:I found this online. The price may be a bit too much for me right now. Plus the color. :-) I bought grey 115V ones, thought that would go well with the red. Not that it really matters to me though. http://www.onestopbuy.com/Isolated-G...plex-27462.aspDoes anyone know of one cheaper? I may try to see if the original one is good enough to still use, but would rather use new.Thanks,RussRIP Mallory, we miss you.
Reply:They are just a common 15 250 volt receptacle, home depot and such carries them.
Reply:Originally Posted by russ69coupeI found this online. The price may be a bit too much for me right now. Plus the color. :-) I bought grey 115V ones, thought that would go well with the red. Not that it really matters to me though. http://www.onestopbuy.com/Isolated-G...plex-27462.aspDoes anyone know of one cheaper? I may try to see if the original one is good enough to still use, but would rather use new.Thanks,Russ
Reply:Thanks! That one will do just fine. I missed it in my search.RussRIP Mallory, we miss you.
Reply:Might want to get a plug or two to go along with it.http://www.onestopbuy.com/leviton/620PV-6599.aspMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-2 06:49 , Processed in 0.073406 second(s), 18 queries .
