tig 355
发表于 2021-8-31 22:13:45 | 显示全部楼层 |阅读模式
Looking to buy one of these tigs and was wondering what the idle current is and if a 60 amp breaker is enough to weld up to about 1/4" ? Is this too much of a machine for a home shop? Tried searching but search engine is down. Thanks guys.
Reply:Well its a hundred amp machine, probably a 30 amp inrush, so you'd probably be ok to 1/4" on a 60 amp circuit
Reply:http://weldingweb.com/archive/index.php/t-3858.htmlArchived threadEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2026-1-2 06:49 , Processed in 0.073922 second(s), 18 queries .
