weldanpower 225 g7 -Idle is high
发表于 2021-8-31 22:13:45 | 显示全部楼层 |阅读模式
Hi,bought this welder and it just runs on high (there is no low idle)-------Also there is nothing on the out side of the machine that shows the code--Is there somewhere inside were i can find the code?I don't have a battery for the welder,I jump start with my truck.Could that be reason of high idle?Thanks ejp
Reply:Code # should be right here:MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Just got home from work and could not wait to see if I had a reply,Now you have to understand that I did look all over this machine for a code and did not see anything-WELL,if I would have cleaned the top left hand front of the welder---------LOL------ I feel like a idiot--LOL Well the code is 9817------------thanks -ejp-------
Reply:Then this should make you feel better - I think you'll find the code # is actually 9317.  http://www.mylincolnelectric.com/Cat...t.aspx?p=32283MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yep,-Your right-some buddy changed the 8 into a 3-----Ok now to the high idle-------got the hard stuff out of the way lol   ejp
Reply:Well I honestly don't know if the charge circuit output can support the idler solenoid load but if I recall correctly, someone else here had one that the idler wouldn't work due to a dead battery and once that problem was resolved so was the non-functioning Auto Idler.So, stick a battery in it and see what happens.   If that doesn't fix it, then you'll have to look at the whole idler circuit and its components.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Ok, I should have the time on Saturday --------Thanks -------ejp
Reply:On Saturday had time to replace the brushes.After work yesterday pulled the battery out of the truck and connected it to the welder.The welder fired up and was in high idle,after around 30 seconds the welder went to low idle (sweet).Then I plugged in a grinder,turned on the grinder,welder went into high idle,after the grinder was turned off,about 30 seconds later I had low idle.Then I made a few welds,the welder ran like it should.Then I pulled the + cable off the battery and the welder when to high idle and it ran that way till I put the + back on the battery.So this machine needs a battery connected all the time.I would say everything is OK.--------thanks---ejp-------
Reply:Well there you have it!  Thanks for the follow up. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-2 06:49 , Processed in 0.070321 second(s), 18 queries .
