Flux Core vs. Steel wire question
发表于 2021-8-31 22:13:43 | 显示全部楼层 |阅读模式
Hi everyone.  I'm new to the forum here.  I live in Central Utah and practice law for a living, but I also live on a cattle ranch and 5 or 6 years ago I bought a Hobart traveler 210.  I bought it because there are endless things around here that need to be welded.  Anyway, the Hobart has been a great machine.  I've done everything from fixing swather parts to making a a pot rack and a boot rack out of horseshoes to building a 2 7/8" 1000 foot drill pipe corral for the buffalo with that Hobart.  Anyway, I also used flux core .035 wire in the thing.  Well today I picked up a ESAB Migmaster 250 from a guy I know that had too many welders in his shop.  Anyway, my question is can I still run .035 flux core wire through that thing.  I know argon makes a far superior weld, but most of the time I'm out in the open welding gates, or hay feeders and stuff like that.  I have an argon bottle and can use it in the shop.  But I was wondering if you can run flux core wire through the Mixmaster 250.  Anyway, any comments would be appreciated.Justin
Reply:Yes you can. You might want to check the drive roller setup though since serated rollers are recommended for flux core vs smoothe rollers for solid wire MIG.Sent from my S4 using Tapatalk1988 Big 50 Diesel CC/CV1982 Weldanpower 225/2101968 SAE 300 motor generatorMaxstar 200SD2015 AHP 200x"The trouble with our Liberal friends is not that they're ignorant; it's just that they know so much that isn't so." - Ronald Reagan
Reply:Thanks!! Originally Posted by njs552Yes you can. You might want to check the drive roller setup though since serated rollers are recommended for flux core vs smoothe rollers for solid wire MIG.Sent from my S4 using Tapatalk
Reply:Don't forget to switch the polarity for flux core.Also, the normal shielding gas for solid wire is an argon/co2 mix or straight co2.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Yea I had to do that on the Hobart.  So its the same with the MigMaster?  Switch the wires around from the positive negative terminals right? Originally Posted by MinnesotaDaveDon't forget to switch the polarity for flux core.Also, the normal shielding gas for solid wire is an argon/co2 mix or straight co2.
Reply:.045” self shielded wire may be the biggest wire you can run through a regular Mig gun. And that is iffy! You may need to get a dedicated flux core gun.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:My 215 amp lincoln came with a 250 amp gun, .045 liner (about .050-.052 +/-) and an .045 grove in a feed roller. It's a sweet step up to .045 if you can pull it off with out a bunch of expense."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:HI Minnesota Dave.  I read in another forum that if it's straight flux core you do not need to reverse polarity.  It says only reverse polarity if it's gas less wire.  Originally Posted by MinnesotaDaveDon't forget to switch the polarity for flux core.Also, the normal shielding gas for solid wire is an argon/co2 mix or straight co2.
Reply:Originally Posted by JCBondHI Minnesota Dave.  I read in another forum that if it's straight flux core you do not need to reverse polarity.  It says only reverse polarity if it's gas less wire.
Reply:Any idea why gas shielded Flux can run on dc+ but self shield cant?
Reply:Some self shielded wires run on DCEP. NS-3M, NR-305, NR-5.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by FlashedAny idea why gas shielded Flux can run on dc+ but self shield cant?
Reply:Thanks gents.
Reply:Retracted
GMT+8, 2026-1-2 06:49 , Processed in 0.072592 second(s), 18 queries .
