Lincoln 180C for a 180 Dual
发表于 2021-8-31 22:09:47 | 显示全部楼层 |阅读模式
What are you guys thoughts on me swapping out a 180c for a 180 dual. Please tell me your thoughts on this trade.
Reply:There are no differences between both welders, same duty cycle at 208-230 volts, same wire speed range, same weight, but if you need the dual voltage I would chice it.Little lower price at the dual.Mauricio
Reply:maybe for a Thermal Arc 181i, but no reason to really swap unless you just like the 180c that muchtackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
GMT+8, 2026-1-2 16:51 , Processed in 0.545985 second(s), 18 queries .
