Syncrowave 250 DX
发表于 2021-8-31 22:04:41 | 显示全部楼层 |阅读模式
Anybody running one of these. I am fixin to buy one and wanted some comments before I do.Yes I can tack it for you.    I know that won't hold but that is what you asked me to do.  Millermatic 350P XR Aluma-Pro push/pullMillermatic 185/spool gunMiller Dialarc 250 HF Water cooledThermal Dynamics Plasma
Reply:Got AL.Purchased mine in June 2004 from BR Welder.  I have the TIG Runner with the water cooler.  It is a great machine.  I guess the only down fall is the size, she eats up some floor space.  I went with the 250dx since I was using a similar machine at the community college and wanted more capacity than the 180-185A machines.  I was looking at the Lincoln 185 and also the Dynasty machines.  They were all nice but I decided to go with the tried and true old school transformer machine in the end.Is this for personal use or a business?  What will be the primary use of the machine? Mine is for personal use at the house but I would like to put it to some use and make some money on the investment.  Make sure you have 100A 240V available.Feel free to ask any specific questions.Have a great day.BrianLincoln Mig 215Miller 211Victor Torch SetMiller Maxstar 200SDMiller Syncrowave 250DX Tig runnerMiller Trailblazer 302 running on LPMiller Extreme 12 VS SuitcaseEllis 1600 BandsawMiller xmt350 CC/CVLincoln Vantage 300
Reply:It is for personal business. I am an electrician at a power plant during the day and have an aluminum welding and fabrication business at the shop at my house. I stayed snowed under from the local boat dealers. I specialize in marine related work. I am running a dialarc 250 now but I need to upgrade because I am welding Honda goldwing motorcycle frames that have been recalled. My dialarc welds them fine but running 230 amps is melting the cover of my torch. 200 amp is the biggest they make in air cooled. (I found a 300 amp weldcraft just came out with) Buy the time I convert over to a water cooler and get the torch and all I would just much rather go ahead and buy a new machine, since the goldwing work will more than pay for it.Yes I can tack it for you.    I know that won't hold but that is what you asked me to do.  Millermatic 350P XR Aluma-Pro push/pullMillermatic 185/spool gunMiller Dialarc 250 HF Water cooledThermal Dynamics Plasma
Reply:Hey Got AL,I want a comparison between your dialarc and this machine when you get it.  I have been considering this for a few years, and since we are both starting from basically the same equip, you have the correct frame of mind...so to speak.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Originally Posted by smithboyHey Got AL, you have the correct frame of mind...so to speak.
Reply:If you're doing a lot of aluminum, you may want to consider the Dynasty machines.  The Syncrowaves are also great though.  Size, as mentioned, is an issue to be considered.  The inverter machines are a bit better on electricity consumption.
Reply:Dynasty 300DX.2002 VW Golf TDi1994 Audi S4
GMT+8, 2026-1-3 05:05 , Processed in 0.097004 second(s), 18 queries .
