查看: 2|回复: 0
I am going to use this for my welding cart
发表于 2021-8-31 22:04:39 | 显示全部楼层 |阅读模式
has anyone ever used a cart like this?  pics ?
Reply:Just keep in mind it will tip over easy with that much weight on top.                                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:The wheels are too close together and top heavy as '' mla2ofus '' stated. I wouldn't put any of my machines on it. You could use the material and rework to be safe.
Reply:Originally Posted by BD1The wheels are too close together and top heavy as '' mla2ofus '' stated. I wouldn't put any of my machines on it. You could use the material and rework to be safe.
Reply:Stack some cinder blocks on it to simulate the weight of your welder. You will most likely find it the most unstable when turning with a heavy weight on it. You can find some larger wheels for it at Harbor Freight, but you may have to extend the axles to make them work/fit.
Reply:Originally Posted by winginityeah i was going to cut a whole in the diamond mesh to lower the tank into it to get the center of gravity down. i like the tires better than the plastic wheels on the carts i see in the stores,  i need to pull it around my yard
Reply:Well, I have a HF 80 amp inverter sitting on an upside down 5 gallon bucket.Smith Toughcut Hobart Stickmate AC/DC
Reply:They dont steer/manuver for $h!t with weight on them and the lever/handle arm doesnt full steer with out hitting the body @ pull angle.They are ok for pulling stuff @ swapmeet, i wouldnt want one as a constant use.esab 260 multimasternew tech 150 invertorlincoln 140 cheapo
Reply:You can buy a hand truck for 40 bucks.Leave the kids wagon alone.
Reply:Originally Posted by farmer37You can buy a hand truck for 40 bucks.Leave the kids wagon alone.
Reply:You are a welder, or a wanna-be welder. Cut it apart and use the materials to build a better cart. Welding carts and tables are great first projects to learn and get better at welding. I usually laugh when a guy wants to buy a welding cart instead of building one. Design it, build it, cut it apart, and rebuild it better. Good practice time. There are lots of welding cart ideas on the forum.Welcome to the forum and welding!Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:They are fairly stable as long as the load is not higher than the sides. I didn't re-read your original post to see what kind of welder you are putting in it to haul around your yard. I've hauled welders and tools in a wheelbarrow. Use it if you want or at least try.
Reply:Originally Posted by drujininThey are fairly stable as long as the load is not higher than the sides. I didn't re-read your original post to see what kind of welder you are putting in it to haul around your yard. I've hauled welders and tools in a wheelbarrow. Use it if you want or at least try.
GMT+8, 2026-1-3 05:06 , Processed in 0.105045 second(s), 18 queries .
