Looks like cast steel am thinking of using 312 to TIG weld, I'd welcome any suggestionsThanks
RichardWest coast of Florida
Reply:That should work. Preheat and then covering after welding to slow down the cooling.
Reply:How hard is the lever?Dave
Reply:I have the part now, its not hard at all, a file will easily score it. I also did a quick arc strike and that files easy tooRichardWest coast of Florida
Reply:Then oods are it is cast iron .They make a good rod for cast iron for TIG and Torch. Bevel both parts for welding or you will need hump/reinforcement weld.I would per heat both parts and use the cast iron rod. If I had I use brazing rod because I have a lot on hand but the rod has better color match to cast iron. I am suprised non of tig welders are on this thread. I do not call myself a tig welder but is very close to Torch witch I do.Dave
Reply:Looks like stamped and formed steel to me. 312 should work great either way.Weld like a "WELDOR", not a wel-"DERR"
MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I agreeBut break looks a high carbon steel or cast iron unless it was worked back and forth.Dave
Originally Posted by 12V71
You do a spark test with a grinder?
Reply:If it is formed steel and was originally bent it is possible micro fractures / stress from that process is why it broke.A full penetration weld should work and remove those stresses in the process. Just curious, why 312 ss for filler?Ernie F.
Reply:Finished!
Reply:Looks great!Ernie F.
Reply:Looks great 👍 Dave
Finished!
Finished!
Originally Posted by 52 Ford
Is it a really small part or are those GIANT Vise Grips?Edit: Pretty good lookin' repair. Are you going to leave it as-is or are you going to blend it back in with a grinder?Sent from my Lincoln Buzzbox using Tapatalk
Reply:Nice job, Richard. You better paint it or I'm going to squeal..
Originally Posted by whtbaron
I hear banjos....
Finished!
